por Marcelo Pereira Campos Sáb 5 Jul - 9:44:16
SE FOR 4C - VAI DE WEBER 40
SE FOR 6C - VAI DE WEBER 44
OU TEM AS REPLICAS DAS WEBER QUE SÃO AS MESMAS CONFIGURAÇÃO EM BEM MAIS BARATO
NA CASA DAS WEBER TEM REPLICA FAJS 40 A R$ 850 COM ENCOMENDA PAC GRATIS, E JA VEM CONFIGURADA PARA SEU CASO, BASTA VC DIZER A ELE COMO VC QUER, OU SEJA VAI ECONOMIZAR UNS R$ 150 REAIS COM GIGLES E ETC...
DIGO PARA IR DE CARBURADOR FORTE, POIS MESMO DEPOIS QUE VC COMPRAR ELES, VC PODE USAR ELES COM O TURBO, E ESQUEÇER DAS 3E.
OU SEJA VC NAO VAI JOGAR DINHEIRO FORA COM AS WEBER, SERA UTIL DEPOIS NO TURBO.
APOS MOTAR O ASPIRADO COM AS WEBER E ANDAR COM ELAS, E VC SENTIR O CARRO AI SIM VC DECIDE COLOCAR OU NAO O TURBO.
FAREI ISSO NA MINHA CARAVAN 1979 4C, COLOCAREI UMA REPLICA DA WEBER 40 E DEPOIS QUE CURTIR COM ELE VEJO SE A NESSECIDADE DE POR O TURBO. ( com certeza colocarei o turbo rsrs mais com a weber 40) RRSS
