Intake Duration at 050 inch Lift:206
Exhaust Duration at 050 inch Lift:206
Duration at 050 inch Lift:206 int./206 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.474 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.474 in.
Valve Lift with Factory Rocker Arm Ratio:0.474 int./0.474 exh.
Lobe Separation (degrees):110
É um comando mais esportivo que o 250s, porém bom pra rua?
